What event is triggered when siren turns off?
If an alarm occurs, siren sounds. After some time, siren goes off.
Is there a event triggered when the siren goes off?
The siren turning off is not an event that triggers a response
In the FAQ i read that when the siren goes off, if not disarmed, the system re-arm itself.
In this case, is the corresponding response, for example \"Away mode\", (if set in \"miscellaneous events\") re-triggered?
No, when the siren times out, it does not trigger the Away mode Response agan as that would not be what most people wopuld want  eg all the lights turning off again
Technically it is not re-armed, it was already armed to away mode. the intruder alarm does not cause the arming node to change. The only thing that happens is the siren turning off. The system remains armed.
If you want a response  to run when the siren turns off, use the Intruder Alarm Response with the timer
Already done, thanks.
No, when the siren present out, it does not initiation the Off mode Salutation agan as that would not be what most people wopuld requisite  eg all the lights turn off again
Technically it is not re-armed, it was already setaceous to departed norm. the interloper consternation does not cause the militarisation computer to replace. The only artifact that happens is the siren movement off. The group relic militarized.
If you want a response  to run when the siren turns off, use the Interloper Alert Greeting with the official
Compter store canada
I am assuming that the above post is not genuine, as there is a link to Computer hardware store. If it is genuine please register again and post without ANY links to irrelevant content
The link has also been removed
