01-17-2012, 06:19 PM
when I add a group address this error appears
knx to comfort Exception
01-18-2012, 02:18 AM
This may be due to old version of Comfigurator or Comfort or UCM firmware.
Which version of Comfigurator are you using? Upgrade to 3.4.0 at least if you are using an older version, go to https://www.cytech.biz/comfigurator.html Also which firmware version of UCM/KNX and Comfort do you have? If you are not sure, open your cclx file, go to Modules, and Scan all modules which will discover the versions of all modules then save the result and send to support@cytech.biz
01-19-2012, 10:03 AM
comfigurator v 3.3.2.0
Comfort II Ultra v 5.211 ucm/knx v 6.011 ucm general v 5.200
01-19-2012, 02:27 PM
Please upgrade to Comfgurator 3.4.0 which can be downloaded from https://www.cytech.biz/comfigurator.html
and try again
01-19-2012, 08:16 PM
I upgraded to Comfgurator 3.4.0
& the Error is solved thanks alot
01-20-2012, 02:29 AM
Thats good
Most exception errors have been fixed with newer versions so using the newest version of Comfigurator is aalways a good idea |
| 1 Guest(s) |
