Response number exceeds maximum value of 1023
\"fixed response number exceeds maximum value of 1023\"
this message appears when i add a new response ,
i deleted responses to reduce the number of responses but the problem is still
Do you mean you have used all the available Responses?
That would be a very complicated program
Can you send your cclx file to support@cytech.biz so we can see what is the problem
yes, i used all the available responses.
i sent the cclx file to ur mail
You can free up the unused Responses so that less than 10123 Responses are used up
Used or Referenced Responses are shown in [color=\"#0000ff\"]blue[/color]
Fixed Responses where the Response number  is fixed is seen in bold
Responses which are not fixed and not referenced in in normal black font
First do Edit > Unfix all Responses so all Responses are not fixed
Then do Edit > Delete Unfixed and Unreferenced Responses to remove all unused responses
This should free up enough unused Responses so that less than 1023 Responses are used
You should see all Responses in blue ie referenced
However the maxiumum esponses is still shown as more than 1023
This is due to a bug in Comfigurator.
Just save the file and re-open it again
You wil see that the maximum response number is less than 1023
thanks,
the problem is solved with the help of u .
