09-02-2012, 07:18 AM
Hi All
I have been trying to setup a everspring Z-Wave PIR (SP103) to work outside and trigger a response that turns on several z-wave lamp / appliance modules. The plan is to cover my front drive with the PIR and if someone comes on the drive after midnight it turns on a security light, flashes the strobe and depending on the value of a counter it triggers a number of internal lamps at different points.
I have tried to follow the instructions in the z-wave3 manual and I have ended up with the items in the UMC configuration as per the pic below.
The only bit I don\'t understand within the manual is if I have to associate the PIR with the modules I want it to control or if comfort is capably of doing this for me.
I have tried setting up the PIR as a sensor, virtual input and response and assigned a simple lamp on response in each part of comfort this relates to, I have tried running the sensor in test mode as well as live mode, the problem with live mode I get no feedback to say if the PIR has seen me, in test mode the PIR lights up a PIR
Comfort Firmware 6.011
Z-Wave Firmware 6.019
Has anyone else manage to get a z-wave PIR working in comfort?
If so can do let me had the idiots guide for achieving this and what is the best virtual input to get the functionality I described above? (I think it is response)
Best Regards
Lee
Best Regards
Lee
