09-17-2013, 01:56 AM
... I have a heatmiser wifi thermostat for the boiler control, just waiting for either a control 4 interface in to comfort (would buy a control 4 system then) or cytech UCM to control this. However, it sort of takes care of itself.
I have ordered 3 z-wave trv\'s as I can get comfort to up the temp if the PIR detects someone in room.
Heatmiser - you need a 240v supply to the thermostate and I ended up installing a relay near the receiver.
Happy to forward the instructions I have for the relay install which heatmiser sent, but did not include in the installation instructions. I would suggest installing before it gets too cold as my heating was down for a couple of days.
lwillerton
Hey Lee,
I have British Gas coming out to spec/quote replacing my Smartfit controls on Monday. Apparently they can do Heatmiser installs?!? Thought I should ask them first as have boiler servicing with them.
I must admit to being quite confused about how best to deploy Heatmiser. I spoke to Heatmiser support today though for advice and they are suggesting I should use a PRTHW-TSWIFI-RF thermostat (in hall) and an RC1-W in the airing cupboard where my current Smartfit/Boiler cables feed back too.
This means I\'ll need the UCM/HM-Eth interface to connect up to Comfort.
Can you see any problems in this? My current Smartfit Thermostat is already 230v so apart from recessing a backbox then it should replace ok.
I purchased the PRT/HW -TS WiFi RF Kit about ã180 can\'t remember if that was inc vat. This can control water and heating.
I put the RC1-W and the relay in the airing cupboard where my wiring centre is, so your spot on there.
Configured the thermostat to work on the wifi by connecting to my laptop.
Connected the thermostat to 240v needed to chop in new back box.
Then paired the RC1-W and the thermostat.
I had an electrician connect to the wiring centre, but found he lacked confidence in this type of tech, even though he connects boilers up in his sleep. He could not get it to work initially so I contacted Heatmiser... they sent out a new wiring diagram which included a relay.
I connected everything up with electrician and it worked fine.
Lee
Wiring diagram forHeatmiser PRT/HW -TS WiFi RF Kit
Did you buy the relay from Heatmiser too? I see they sell one.
Hi.
I purchased this from Maplins:
http://www.maplin.co.uk/30a-spdt-power-r...cification
PwrRly30A SPDT240Vac
Order Code: N24AW
In fact I need to go and buy another one just in case it fails. I have purchasd the socket and wired to that so it is a simple unplug and plug.
Lee
when you say you purchased the relay socket, can you advise? It this the blue part shown next to the relay as thought this is included?
they had the relay in stock as well..
Part code N19AW according to Maplin. Sold separately
Vangelis
Correct... I had been without the boiler for a few days. On the day I got the info from Heatmiser I reserved what I thought was the relay and when I got there it was the socket...fortunately they had the relay in stock as well..
Do you have a static IP? I don\'t and inorder to get things to work correctly I use No-ip which has a client that runs on a PC and updates any IP changes forced by ISP
Therefore, when setting up heatmiser, comfort or anything else for that matter from Internet to home becomes very easy.
The problem is you need a PC on all the time and unless you pay $29 I think the host name gets deleted after a month and needs setting up again.... Bit of a pain so I paid the bill to be honest.
I am OK as I run a small atom based web server 24x7 (takes about 28 watts to run). One thing if I hadn\'t done this way would have been to use a dynamic dns client on a on a raspberry pi. This could run 24x7 on pence per annum or a few batteries and keep IP address updated.
lwillerton
Hey Lee,
Lee
Hi.
Order Code: N24AW
Lee
Vangelis
