09-21-2013, 07:22 AM
If you are signed into comfort, then load a new config and try to access the system again ie \"System Information\" then if the cached credentials are not the same then you first get an error (see below) popup and then the next time you try access then it correctly presents the sign-on box.
Whilst I guess there is a possibility that two configs could have the same user codes I\'m suggesting that would not be the norm.
Therefore could I propose that if you load a new config then it automatically resets the credentials so that you go straight to the sign-on popup and not via the screen below.
