Heatmiser UCM Functions
Just installed the UCM/Heatmiser and integrating with my heatmiser network.
Couple of questions...
Firstly, can you put the thermostat in \'frost protection set back\' mode? E.g. by setting the \'Thermostat\' flag in comfort it turns the whole thermostat off - LCD and all... On the thermostats they have a \'power\' button which when press turns off the program and turns on \'frost protection\' mode, and the snowflake appears on the thermostat. This would allow me to \'set back\' when going into vacation mode...
Secondly - I\'m finding I often have to write values twice. For example I have 5 thermostats on the network (plus a NetMonitor, which was off during learn) and I have a a Response that sets the \'Theromstat\' flag on them all off. I find if I run the Response it doesn\'t always hit them all, but if I run it twice it does. Any ideas?
Finally - \'Get Status\' in Comfigurator is greyed out, so I can\'t see any status information....
Looking good though, another nice easy integration which makes life easier than using IR codes etc...
Cheers
Simon
The Frost Protection parameter is a Read only value
The Frost Protection setpoint temperature can be changed via a counter
There is another parameter Run Mode that can be changed (0 = heating, 1 = Frost Protect, 2 = Cooling) that may be used to change the mode. Currently it is not one of the parameters mapped to Comfort. We will see if that can work in the next firmware
For the problem of having to run responses twice, it may be the Netmonitor interfering on the bus. Can you remove Netmonitor and test is the error still happens
If it is due to Netmonitor, we may have to look other ways like repeat the transmission
Thanks ident - that Run Mode parameter would be particularly valuable if it could be integrated.
Will do some testing without NetMonitor - do you know if it makes a difference if it is physically connected and powered down? E.g. the easiest thing for me to do is simply power it down but would it still leave a load on the rs485 network?
Cheers
Simon
Powering down should be OK, it should not affect the bus if properly designed
I\'ve now tried turning off the NetMonitor and its no different, most Responses need two \'shots\' to get all the thermostats.
Is the heatmiser network topology important? I have 5 x Thermostats, 2 x UH-1 and 1 x NetMonitor. All the stats wire back to the UH-1\'s with them and the netmonitor wired in a daisy chain, with the UCM daisy chained on from the netmonitor via some structured cabling...
Thanks, Simon
did you connect the 12V supply  from UH1 to the 12V into the Heatmiser plug in board? This provides an isolated 12V supply to the plug in module
When the 1st response does not work, which are the thermostats that see the command and which do not. Can this be isolated to the ones that are connected to 1 of the UH1s?
Why are there 2 UH1s?
Hi Ident
The UCM/Heatmiser I have I believe is an \'early\' version that has the RS485 on the base board, thus has no separate 12V terminals... Could that be related?
The thermostats affected are not always the same, it seems variable. I would say first time I get 50% of the thermostats, and 2nd time I get the rest - but which ones are variable...
I have 2 UH1\'s as I have three Underfloor Zones and 2 Radiator Zones. A UH1 can only support one Radiator zone, so I have 3 UF and 1 Rad on one, and just 1 Rad on the other... I believe they are passive to the RS485 though?
Thanks for your help.
Simon
Hi, simond,which firmware you are using for the UCM heatmiser,7.029,7.031 or 7.033? by the way, can you check your setting for heatmiser module about the output delay, temporary you can set to zero and see your response any difference...
Hi HeFeng - thanks for the reply. I\'m using 7.033 (have been since initial install). I can\'t seem to find an output delay setting - could you tell me where this is?
Thank you, Simon
Hi, simond, maybe i made you confused, the heatmiser module out put delay is on module\'s optional setting,see below:
by the way, you can send your cclx file to support@cytech.biz, we can simulate your case.
[img]data:image/png;base64,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[/img]
