ULT 7.071 to 7.078
ULT 7.071 Beta
Known Bugs
  1. When Zone Restore Box is checked, meaning when the zone is restored following an alarm, it may not report the zone restore to CMS or GSM in some cases. From 7.059
Changes from 7.068
  1. Wait for Timer delay action 190 - if timer value=0000, use last action value as timer value. This allows values returned from previous actions to be used as the timer delay in seconds.
  2. When Keypad broadcast announcement is disabled, if there is a full alarm (alarmstate=3), the keypad broadcast is re-enable so that the alarm sounds can be heard on all keypads.
  3. If a  counter value is changed by a UCM, Comfort will broadcast the counter change to other UCMs, but the UCM which originated the counter change will ignore the counter change, so as to avoid the UCMs counter getting changed again which may cause race effects with certain systems (like Zwave dmming) broadcast. This requires UCM of each type firmware 7.068
  4. Multiply action - fixed BUG check wrong limit. intermediate result of multiplication of 2 x 32 bit values if  > 32767 gives wrong result.
  5. Implemented action 157 divide action (requires Comfigurator > 3.10.x)
  6. prevent KP06 volume from exceeding 50 due to possible damage of speaker
ULT 7.072 (Beta)
Fixed  Bug from7 .059
When Zone Restore Box is checked, meaning when he zone is restored following an alarm, it may not report the zone restore to CMS or GSM in some cases. From 7.059
ULT 7.076 (Beta)
Bugs fixed
  1. Fixed BUG Comfort app could not arm system
  2. FIXED OLD BUG x10 received code locations for x10 all lights on and all units off were swapped. X10 all On should be before off follow all other units on then off
  3. Fixed Bug on GSM - If control menu feedback is empty, sending a Home control command (4xxx) had no reply.
New Features
  1. Support command to erase 1 sector on KT03 to support latest KT03 System parameters write and read feature
  2. Added action 157 Divide action (requires Comfigurator 3.10.5)
  3. CM command used by Apps will check authorisation for Control Menu
You say ucm firmware 7.068 is required, but latest firmware fro eth and velbus is 7.062?
Not all the UCMs with firmware 7.069 for all types are available yet
UCM 7.069 beta is now in the website downloads
Firmware  7.078  - Changes from 7.076
Known Bugs
  1. Actions Add counter, Add counter give wrong answer from 7.039
  2. Sentence upgrade without vocab upgrade does not work, but  Full vocabulary upgrade upgrade works.
  3. If telephone line not connected, and Ignore Line Cut Box is unchecked  then alert zone will cause an  immediate alarm - This is an old bug. To work around, check \"Ignore Line Cut\" Box in Security > Configuration Flags
  4. Action 73, 16 Get  keypadId/ If Keypad ID does not work
Changes and New Features
  1. Fixed Bug - Deg C/F always was set to deg F in Location 39 (This feature is not used in Comfort yet
  2. Fix BUG from firmware 6.010  caused F? Query replied FL. Flag query did not return the correct value after reset. Flag states are not changed by soft reset, but F? Always Returns off after reset.
  3. Fixed bug DA09 followed by phone offhook causes tone to be generated until reset.
  4. Sign in tamper can only be reset by local ie keypad or phone, not from UCM as that may come from Internet.  Only 1 correct sign in from local phone or keypad resets sign in tamper
  5. Arming/disarming  fixed problem when system is arming with zones open, but is disarmed without arming,when zones are restored, the restore zones are reported to cms and sms.
  6.  Logic engine Firmware can bypass and unbypass zones
Firmware 7.078 has been released
Bug found in Firmware  7.078
Sentence upgrade by itself does not work. The upgrade completes but the sentences are not upgraded. Please do a FULL vocabulary upgrade instead, which takes 20 + minutes
