Comfort 2nd Generation Android Phone and Tablet apps will be released within the next week. Note that this requires ETH03 firmware 2.16 (download from https://www.cytech.biz/eth03_firmware.html ) and Comfort Server Manager 2.06 (included in Comfigurator 3.10.4)
[color=\"#ff0000\"][size=\"4\"]Note: For this update, the older version must be uninstalled before installing the new version 1.6. This is because of differences in the data structure due to the extra port which cannot be updated. After uninstalling the older version, the new version can be installed[/size][/color]
The new feature will be the ability to select the port for Local or Remote (Internet) connection from the log in screen
You can select Local1, Local2, Remote1, Remote2 port for connection.
ETH03 2.16 allows 2 ports for connection eg Ports 1001 and 1002
This allows 2 applications to connect to Comfort eg Android, iOS app or Comfigurator at the same time.
However only 1 connection can be made at one time to one port. If the port is busy, the application can connect to the other port.
The new version of the app allows the user to see which port is free.
Check one of the boxes Local1 or Local2. If the port is free the app will show \"Connected\" as in the above screenshot. The Login button will be visible.
If the port is busy, it will show \"Connecting...\" and the Login button is grayed out. Switch to the other local port to connect.
For the 2 Remote ports, there should be 2 ports forwarded on the router for connection by Internet
The Setup screen is shown
In the above example, 2 local ports 1001 and 1002 and 2 remote ports 8084 and 8085 are entered.
The 2 local ports must be set-up using Comfort Server Manager
2 2 remote ports must be set up by Porty Forwarding on the router
If any of the local or remote ports are not set up, the ports will be grayed out and cannot be selected on the login screen
Download ETH03 firmware from https://www.cytech.biz/eth03_firmware.html
Comfort Server Manager 2.06 is included in Comfigurator 3.10.4
