12-23-2015, 09:30 PM
Hi All.
Quite new to Zwave, - just installed & configured UCM-ZWAVE3, setup a small Zwave network with an Aeotec keyfob remote gen 5, and some TKBhome plugin modules.
All mostly has gone well, the first module I setup was a simple relay, which works just dandy, but the 2nd module I\'m trying is a dimmer module, and it is a bit mental...
I should note that I am using CBUS as my control interface, the control path is CBUS-COMFORT-ZWAVE, which I obviously achieve by mapping the same comfort register to both CBUS and Zwave endpoints. As I say, this works fine for a relay module, CBUS wall switch turns the zwave module on/off reliably and quickly. (This is mapped via a Comfort flag)
I Wish I could say the same with the dimmer! - I have setup the same mechanism... using a Comfort counter this time of course rather than a flag. the mapping does \"work\" - kind of... I\'m using the CBUS WISER to give me a GUI on an iPad for control... when I first pressed the widget for this new dimmer, it switched on at full brightness, so I thought it was going well... - however, when I press & hold the widget on the iPad, instead of dimming smoothly, the widget - which shows the dim level as a percentage does not - even onscreen - travel up or down through the 0-100 range progressively.. instead the % indicator jumps randomly all over the place... it may go from 17% straight to 38% then to 89% with no transition in between... whilst this is going on, the connected lamp (incandescent) does not dim in sync with the widget at all, instead, it may also jump around between wildly different dim levels (not related to what\'s onscreen) or often it seems to do nothing until I remove my finger from the icon at which point the dim level shown in the UI will usually then jump back to some other random level (after I\'ve stopped pressing it!) and the lamp may or may not follow suit...
It\'s completely mental, and totally unusable...
Anyone got any thoughts as to what might be going on here?
I haven\'t\' tried dimming with the zwave remote yet, - I don\'t plan on using that as part of the control strategy, everything needs to be controlled via CBUS wall switches, or directly from Comfort responses.
TIA
Paul G.
TIA
Paul G.
