I have set up a simple Z-Wave network with a Vera Edge controller. I have included the UCM/Z-Wave in the network. Comfigurator knows all the Z-Wave nodes and I can use Comfort responses to control the Z-Wave actuators and having associated flags with the nodes, Comfort knows the status of the actuators when they are changed by Comfort or by Z-Wave nodes.
In other words, everything seems to be working as expected except the Vera Edge has \"Error: unable to get any information on node\" against the UCM/Z-Wave node. Vera Edge seems to think the UCM/Z-Wave is a \"SceneController1\". Repeating the learn process for the UCM/Z-Wave doesn\'t make any difference.
I suppose as it all works I shouldn\'t worry but clearly something is not quite right with the setup which may cause problems in the future. Anybody any ideas?
Adrian has it correct; the Comfort Zwave UCM always is the secondary controller.
My first primary controller was an ACT Homepro, then i upgraded to a Remotec ZRC100 and now finally settled on the Fibaro Home Center 2 (did that as most of my units are Fibaro anyway)
I hear Vera is good too as well.
Another user who has Vera Edge verifies that he also has the message. But otherwise there should be no problem. Vera thinks UCM/zwave is a scene controller for some rason
Yes I have a Popp Wall Controller included in the Z-Wave network and Vera is quite happy with that. I have also added a Comfort Virtual Node and again it all seems to be working fine (I can trigger Comfort responses with Z-Wave sensors) but have the same error message against the virtual node in Vera. Looking at the log, Vera is sending a \"reconfigure\" action which the UCM/Z-Wave ignores. (At least I think that\'s what\'s happening - the log is quite difficult to interpret without a detailed knowledge of Z-Wave protocols! )
lobby the major primary controller companies so that the Comfort/UCM is recognised as a \"known\" secondary controller; and thus maybe a bit better supported. I\'m sure the list is longer but ones like Vera Edge and Fibaro Home Center 2 are two we all seem to use on this community as a start. For example I use Fibaro and they still haven\'t created a \"template\" for the UCM even though plenty of other templates for devices are getting created.
I know Cytech resources aren\'t infinite and I\'m sure you want to interface to as many devices as possible so that you maximise your sales activities, I also think that maybe a few of these integrations like CBUS and ZWave should have \"premium\" developer status and maybe have features that go a tad further than some of the other \"first gen\" integrations.
Personally I want a reliable retrofit solution and hoped Zwave was it, but I\'m sure others want a new build solution and if Comfort could \"really..really\" (that\'s technical for more features!) support these then life would be sweet!
In terms of my UCM/ZWave3 I sort of agree with Vangelis, I don\'t really use mine much either now.
I just added a Vera Edge, I selected generic device from the Vera Edge U17 screen. I also get the same message mentioned in this post and also Vera thinks the UCM/ZWave is a scene controller.
Is generic device the right device to select to add the UCM/ZWave
I have not tested yet but will try over weekend
05-06-2019, 02:22 PM (This post was last modified: 05-06-2019, 02:24 PM by bmistry3.)
Chiu / Forum members - Please help..
As per my previous post, I have a Vera Edge setup with Fibaro Dimmer and Fibaro Motion sensor. I also have Philips Hue plug-in in Vera U17 software.
All this works fine on Vera U17, motion sensor detects motion and temp, The dimmer module can be controlled from Vera U17. I can switch on/off lights and dim the lights. I can setup scenes in Vera U17 and on detecting motion it can switch dimmer 2 module or the Philips Hue lights.
I am struggling with UCM Zwave. I have it installed in my comfort 2, no errors (See pictures of module properties and mapping). My Vera Edge U17 see\'s it a a scene controller but I get \"unable to get information from node\" in the Vera U17 software.
In comfort, the Fibaro sensor appears as a Slave_Garage_Door and the Fibaro dimmer as Slave_Multichannel.
When I try the \"On\" & \"Off\" function it does not work, the lights do not come on when executed from Comfort.
