Problems in knx2
Every time i start the configurator with last default file the program reports the following mistake and the software don´t start.
System.NullReferenceException: A referência de objecto não foi definida como uma instância de um objecto.   em Comfort.UcmKnx2ToComfort.get_RegisterName()   em Comfort.UcmKnx2ToComfort.AddReferences(Dictionary`2 references, UcmKnx2 ucmKnx2)   em Comfort.UcmKnx2.AddReferences(Dictionary`2 references)   em Comfort.Configuration.BuildReferences()   em Comfort.Configuration.GetReferences(ConfigListItem configListItem)   em Comfort.Response.FlagOmittedResponses(Configuration configuration)   em Comfort.Response.EncodeResponses(Configuration configuration, Boolean flagRequireWriteToEeprom)   em Comfort.Form1.SetNewConfiguration(Configuration newConfiguration, Boolean keepPanel)   em Comfort.Form1.NewConfiguration(String filename)   em Comfort.Form1..ctor(String filename)   em Comfort.Program.Main(String[] arguments)
My configurator ver is 3.12.1 but i think the problem is with the latest update to knx2 of my knx ucm.
Can someone help me ?
Kind Regards,
Please send your cclx file to support@cytech.biz so we can check
Please make sure that you ave done a scan for modules and have saved the file
Ok,
I will send the file through email
Thanks,
Marco
I opened the file Alarme 1_11_2017 but did not get any exception, even if set to Open Last File
Does the problem still happen for you?
Thanks for the reply. The problem was with the installation of Configurator, and not on the cclx file. I´ve done a fresh install and everything works well now. I clean all files on the installation directory before installing the new configurator.
Thanks,
