Eth03 not live on the network
I have a U/UCM with Eth02 which I used many years ago with a RFXCom system, I want to start using again as a regular UCM for Comfigurator.
What I\'m seeing is it won\'t connect to the network, as in the network switch sees no link. It\'s running 7.117 according to Comfigurator.
If I press and hold SW1, after 2 seconds the Eth02 springs to life and the link indicator on the switch shows it\'s connected. As soon as I release SW1, it drops.
I tried this by holding SW1 for 7 seconds whilst powering the UCM back up by reconnecting the RS4 cable, same issue http://www.comfortforums.com/forum119/3522.html
If I stand there, hold down SW1, DSManager does see the Eth02 on the network and you can access it. As soon as SW1 is released, it\'s gone again.
Any ideas as to where I\'m going wrong?
I dont think you have done anything wrong. I suspect the eth02 has given u the ghost after too many years Sad. I suggest to get a ETH03. But ony if your UCM is not the old non flash type
Even tho the Eth02 works perfectly well when I hold down the UCM\'s SW1 reset? I\'ve added a picture above.
We have not seen this issue before. that tibbo nodule is not in production and we do not have any of these devices, so I do not know what could be the problem, I would suppose that something on the ETH02 board has a problem
With the picture above, does this indicate an Eth03 is suitable?
Sorry, I did not see the \"Universal\" label.  That is a Universal UCM, it is used for talking to other devices so eth03 would not allow you to use it with Comfigurator
In the UK if anyone wants to buy a UUCM! No use to me any further.
