Threads: 11
In our location we have numerous power failures, which normally isn\'t a problem. But on the last two power failures an alarm state has been triggered. Security was in Security off and the only way to silence it was to do a system reset on the panel.
About a month ago I fitted a new battery as the old one was failing the battery check.
I have also been having the odd false alarm, luckily mainly on a door that doesn\'t trigger full alarm but keeps announcing door is open when not. I replaced the contact, still happened. Then I swapped the zone over and it happens on the other door on same zone. Have also had three other Zones trigger with no apparent reason, the others are PIRs
Any ideas at to what could be causing these issues?
Joules
Threads: 31
08-09-2021, 10:36 AM
(This post was last modified: 08-09-2021, 10:37 AM by Swiss-Toni.)
Depending on what comfort unit you have I would clean the eol pins as they can oxidise and loose contact cohesion, Same applies for all conections with the wiring ect which can trigger alarm zone failures,
Threads: 11
Thanks Swiss-Toni,
I did think that might be a possible cause for the false Alarms.
Presume just clean with contact cleaner?
Any ideas about the Alarm after power failure which cannot be cancelled by user code only a reset.. puzzled why power failure should trigger Alarm sate in first place.
Joules
Threads: 880
Also read the Event log to see what alarm has occured
Threads: 11
Hi still having problems will alarm going off after power failure. Unable to sign in to cancel and only way to stop it is to press the reset button on comfort.
snippet of log attached
Any ideas?
[img]data:image/png;base64,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[/img]
Threads: 880
Which is the false alarm? I see a power failure causing a pwower fail alarm which is corret followied by Power restore and disarm
Threads: 11
I was not at home so presume this is the chain of events
14:54 AC Fail 0 - Power fails briefly then is restored but it has already started to dial me.
I answered and could hear alarm going off.. I could set to security off to stop it remotely.
My wife was home and tried to enter her code on the keypad, but alarm still wouldn\'t stop. I instructed her to remove panel and press reset button.
I haven\'t altered any settings for a few years ( I am just about to do a big system expansion) and it has only started recently, it just used to dial me but not trigger the siren.
What is the difference between AC Fail 0 and AC Fail 48..also presume the siren is caused by Alarm type #Powerfail (8)
I am having so many issues with this lately, with false alarms etc, my wife wants me to change to something else but I have just spent nearly ã1000 on parts to do the Expansion, so need to get it sorted.
It just seems to do so very strange things lately...I am wondering if there is a hardware issue?
Threads: 880
If you can disarm remotely then your wife should be able to disarm by keypad.
Do yiou mean the siren would not stop after entering th code? Are you sure the code was entered correct, and the keypad did not give a long beep to indicate wrong code?
Power Failure should not cause the siren to sound. This is in the alarm Types Power failure setting. Please check this or send the cclx file to support@cytech.biz
If you signed in and the siren does not get silenced try 0 for security Off after signing in on the keypad
