Migrate from ETH02 to ETH03
I recently received an ETH03 module to replace my existing ETH02 module.  A couple of questions:
1) Can I simply install the ETH03 module on the existing UCM board that currently hosts the ETH02 module?
2) Since I use the ETH02 board to access the system via Configurator is there a way to upgrade it over the network or do I need to connect to the Comfort alarm via a serial connection in order to configure the ETH03 module?
Thanks.
yes, just unplug the eth02 and plug in the ETH03 submodule to the UCM base board
You can configure the ETH03 IP address by using Comfort Server Manager see instructions here http://www.comfortforums.com/thread-3695.html
No drama...worked perfectly!
As always, thanks for the quick resposne.
Big Grin
GREAT
