I have just powered up a CBUS to KNX translator
I have both CBUS and KNX connected
I am unable to connect using the USB cable.
In settings there is no pull down menu to indicate a USB found and in the serial no line its just 'blued out' I cannot type anything.
If I go transfer system information then I get a small window appear
"error opening USB port: FT_INVALD_HANDLE
If I remove the cable then it says: FT_DEVICE NOT FOUND
I have just gone into device manager and can see an active USB Comport4 (only one present and it disappears when cable removed).
- Says device is working properly
- Set at 9600 bits per second
- Parity : none
- Stop bits: 1
- Flow control: none
Under events this must have happened in the background ! : "Driver Management has concluded the process to add Service FTSER2K for Device Instance ID FTDIBUS\VID_0403+PID_6001+AH00SBLYA\0000 with the following status: 0."
I have just tried changing the SB cable
I have also tried changing the USB daughter board
No change to the end result
- Parity : none
- Stop bits: 1
