Update icons in KT01
Hello,
to update icons on the KT01, KTman.pdf says to send CBUS On (or Off) command like this:
CBUS On 3,1
where first number is UCM ID and second is the group.
But in Comfigurator \"Response wizard\" , there are other 2 options to add to the command:
\"Application\" and \"Remote network bridges\".
What these options means? How can i tell to use \"lighting\" in \"Application\" field (only numbers are allowed) ?
Thank you.
Ok, \"lighting\" application is 56.
correct, and you dont have to use network bridges
