Recording Audio via UCMAudio to Comfort - HOW !?
Put simply, how can you get an audio feed from a PC (ie a pre-recorded item) into Comfort as a Reminder Message
Not by using a Keypad Mic.
I did try to look at getting the PC to just play a stream via the UCMAUDIO to the doorstation but that appears to be impossible.
Thnx
bump
Bump
Use WizComfort...
Connect PC to UCM Audio both sound wise and data wise, then using WizComfort you can use the SW keypad just like you would the real one to access and record the reminders. Just hit play on the sound file after the beep and # at the end.
