Comfort Automation/ Security System Forums > Products > UCM > Ethernet UCM/ETH03 > Port Forwarding to ETH03/ Dynamic DNS Setup
 Posted: Friday Feb 9th, 2024 12:48 am
To access comfort remotely by dynamic DNS, you need to have an account with a service like no-ip or dyndns.org . This may not be free but you get a number of addresses that you can use eg user.ddns.net
Your router should support the ddns service. You will get a user name and password to log in to the service. As an example, see below
Other routers will have different menus to set this up.
Next, set up Port Forwarding on the router as shown in the example below. You need to map the internet Port to the Local IP Address and Port
Again, different routers will have different menus to set this up.  When this is done you can use the dynamic IP address eg user.ddns.net as the remote IP address in Comfigurator or the Cytech Mobile app
 Current time is 11:41 pm
