Search by username
Comfigurator 2.2.1
 New Topic   Reply   Print
Status:  Offline
 Posted: Saturday Jul 28th, 2007 10:13 am
 Quote  Reply
This fixes the known bugs in 2.2.0
Download from http://www.cytech-technology.com/temp/software/Comfigurator2.2.1_Single.zip
Please note that Engineer Code is required for download and upload. First, press F0 to enable Engineer code
The default Engineer Code is 6789
Comfigurator Version 2.2.1 June 2007
HISTORY
V2.2.1 25 July 2007
Bug fixes
  • Fix problem saving file with sensor register as feedback type
  • Fix problem saving file with sensor response
  • Fix crash when clicking outside Zone, Zone Type and Alarm Type dialogs
  • Fix incorrect values in Zone Type dialog
  • Retain sort order following response insertion
  • Append CR to Rako command
  • Fix problem in 2-byte response number allocation
V2.2.0 15 June 2007
Bug fixes
  • Fix problem with response compilation if response number = 255
  • Fix problem with erroneous values in event log listing
  • Save CCL values using English locale to avoid problem with comma as decimal point in Siren duration
  • Limit counter value in IF statement to 254 to avoid erroneous end of response detection
  • Fix incorrect values set for reminder message destinations
  • Support user-entered branch actions
  • Fix exception on incorrect user-entered action codes
New features
  • Hide ringer details for Comfort II
  • Remove licensing checks
  • Remove alpha pager
  • Require engineer code for up/download. PRESS F0 to enable Engineer Code
  • Disable UCM concatenate if not CBUS
  • Launch WizComfort
  • Edit zones, zone types and alarm types using popup dialogs
  • Right-click on zone type in zone popup to display/edit zone type
  • Add descriptions and enable editing of tuning parameters for Comfort II
  • Associate names with X10 transmitted codes (referenced within responses)
  • Support UCM type Rako
  • Support UCM type Lutron
  • Support UCM as target for reminder messages
  • Display some actions in more than one category in Response Wizard
  • Support Sunrise/Sunset times
  • Support firmware download
  • Support unknown action codes
  • Allow either IP address or hostname for network connection
Known Issues
  • Dynalite UCM commands appear as SEND RS232 actions
  • Changing Alarm Names in the Alarm Types popup window may corrupt NonDetector alarms. DO NOT change the Alarm Names using the pop up window
  • Problem when spaces are entered in the popup windows for Alarm Types, Zones, and Zone Types
  • Some ULTI command descriptions are not correct eg ALL OFF
  • Executing very long Responses directly from Comfigurator Responses window could crash the program
  • Sensor Feedback is not downloaded/uploaded correctly for the Control  Menu
  • Some actions for Cbus after uploading get changed
  • When file system is converted to one with fewer responses, eg File System 34 (Ultra) to 31 (Optimum), the Responses which are fixed and over the limit for the new file system remain displayed without errors. If unfixed these Responses will be renumbered to a lower number or they will appear with a strike-out
  • Closing the Monitor I/O window after downloading or uploading may cause th software to hang.
  • Upload Event Log for Comfort Ultra II may show the wrong percentage > 100%, but the event log will still be uploaded correctly
Status:  Offline
 Posted: Wednesday Sep 5th, 2007 02:45 pm
 Quote  Reply
Note the "Known Issues" for Comfigurator 2.2.1
An interim release 2,2,2 has fixed these known problems, see http://www.comfortforums.com/forum20/798.html
 Current time is 03:10 pm
