The new UCM/Velbus connects directly to Velbus, ie 4 wires 12V, GND, CANH, CANL instead of to the Velbus VMB1RS RS232 Interface as in the previous version. The Velbus system is electrically isolated from the Comfort system.
This is a significant improvement in simplicity of wiring connection as well as increasing system reliability in not needing additional VMB1RS module and a RS232 cable, and also realises cost savings. It makes the Velbus system a more attractive candidate for system integrators to implement lighting, blinds and heating control with Comfort.
Up to 512 Velbus channels are supported
The Velbus Modules supported currently are
Minimum Comfort Firmware 5.215 recommended
UCM/Velbus Firmware Velbus 5.230 (https://www.cytech.biz/ucmvelbus_firmware.html )
UCM firmware (for programming) UCM 5.212 (UCM 6.002 recommended)
Comfigurator software version 3.2.8
UCM/Velbus Manual can be downloaded from https://www.cytech.biz/ucmvelbus_manual.html
UCM/Velbus on Cytech Website https://www.cytech.biz/ucmvelbus.html
Many thanks to Velleman in Belgium for working with us on this
- VMB1BL - 1 channel Blinds
- VMB2BL - 2 channel Blinds
- VMB1RY - 1 channel Relay
- VMB4RY - 4 channel Relay
- VMB1DM - 1 channel Dimmer
- VMB4PD - 4 button Pushbuton Module
- VMB6IN - 6 input Module
- VMB8PB - 8 button Pushbutton Module
- VMB1TS - Temperature sensor
- VMB1TC - Temperature Controller
- VMB1LED - Professional LED Dimmer Module
- VMB4RYLD - Programmable 4 channel Voltage Out Relay Module
- VMBRYNO - Programmable 4 channel Relay Module
- VMB4DC - 4 channel 0 (1) to 10V Output Controller
- VMB4DME - Dimmer for Electronic/ Resistive Load
