Upgrading Comfort firmware
 Posted: Sunday Nov 4th, 2007 07:01 am
Online
Instructions for upgrading Comfort Flash firmware by UCM Programming Cable using Comfigurator can be found at
http://www.comfortforums.com/forum4/1216.html
Instructions for upgrading UCM and Slave Firmware using the UCM Programming Cable can be found at http://www.comfortforums.com/forum4/1782.html
Updated March 2010 with detailed instructions
 Posted: Sunday Aug 14th, 2011 07:32 am
Online
The upgrading methods mentioned in the above post are by using the UCM Programming cable
The new Comfort, Slave and UCM version 6 firmware that aree being released can be upgraded without the UCM Programming cable, either by "Direct Connection to PC" for UCM/232, UCM/USB and UCM/Ethernet, see http://www.comfortforums.com/forum4/2283.html
or for  modules by Comfort Bus for Comfort, external UCMs (KNX, Cbus, GSM etc),  see http://www.comfortforums.com/forum92/2409.html
 Current time is 05:43 am
