Minimum Confort Firmware version and Iphone app - Printable Version
+--- Forum: iOS Apps (https://www.comfortforums.com/forum-122.html)
+---- Forum: Comfort iPhone App (1st generation) (https://www.comfortforums.com/forum-96.html)
+---- Thread: Minimum Confort Firmware version and Iphone app (/thread-2708.html)
- rportela - 01-25-2012
Hello,
This is my System Information window on Comfigurator.
On the Iphone, I can see the \"Control Group 0\", mas the programmed responses are not executed.
Is it a firmware issue ? (old version)
Thank you
- ident - 01-26-2012
The minimum Comfort firmware is 6.004 and UCM firmware is 6.002, see
http://www.comfortforums.com/forum96/2327.html
- rportela - 01-26-2012
Does this board support firm.6004 ?
To upgrade, does it have to be wiith cable, or can it be through Ethernet?
Thank you for your help...
RP
See http://www.comfortforums.com/forum4/1216.html on instructions about how to upgrade firmware 5.xxx to version 6.xxx This needs programming cable, but once the Comfort firmware has been upgraded to version, future upgrades  need not use the programming cable, as described in http://www.comfortforums.com/forum92/2409.html
You should also upgrade the UCM 6.002 firmware to the latest UCM 6.xxx firmware see http://www.comfortforums.com/forum4/2283.html
