Comfigurator 3.2.4 Beta
New Features
  1. KT03 Save Template and Load template Buttons next to Write to EEPROM and Read from EEPROM allows KT03 configuration to be imported and exported to other files
  2. Comfort Bus Monitor and IR Learner in Tools have been incorporated into Comfigurator instead of being stand-alone programs so that the Connecction settings of Comfigurator can be used. However Comfort Bus Monitor cannot be used for UCM/Ethernet due to limitations of the buffer size of the Ethernet Tibbo module.
  3. Universal UCM support has been added but not complete.
Bug Fixes
  1. In KT03, changing the Font size of text in Button Elementcaused exception
  2. For Velbus, if a blank EEPROM is used in U2, an exception occured aftre learning when writing to EEPROM
  3. Responses referenced by KT03 buttons were not shown as regerenced in blue
  4. In KT03 Comfigurator, Input zones allowed Zones 1 to 64 but not RIO inputs 129 to 248. Now RIO zones can be referenced
  5. KT03 simulator Home and Back jumps did not work correctly
  6. When Say Word Action is the last action  in the Response, Comfigurator did not append another 255 to end the Response so the Response may continue to the next line.
  7. When Send RS232 is the last action in the Response, Comfigurator did not append another 255 to end the Response so the Response may continue to the next line
  8. IR Receive Responses - if assigned to NULL, called Response 255 if the IR signal is received.Null Response is correctly addressed now.
\"Use Branch Actions\" for Comfort I
Branch Actions were introduced  in Comfort I firmware 4.232. This allows Comfigurator 3 to code If/Then actions correctly. Comfigurator 2 has a checkbox called \"Use Branch Actions\" in Modules & Settings. This checkbox is not found in Comfigurator 3 as it will automatically apply Branch Actions when the Comfort I firmware is 4.232 and above.
If you are converting a comfigurator 2 file for Comfort I to Comfigurator 3, and if the Comfort I firmware is 4.232 and above, please check the \"Use Branch Actions\" box on Comfigurator 2 and save BEFORE conversion to Comfigurator 3 otherwise an Exception will occur when opening in Comfigurator 3
If the Comfort I firmware is lower than 4.232 uncheck Use Branch Actions in Comfigurator 2 Modules and Settings before conversion to Comfigurator 3
Please download beta version from https://www.cytech.biz/comfigurator.html
Please report any bugs to support@cytech.biz
