Whats New in Comfort App v 1.42
The new features on v1.42 of the Comfort iPhone are are shown here
Minimum firmware
  1. UCM/Ethernet 6.002 or above
  2. Comfort firrmware 6.004 or above
Audible feedback when any key is pressed was the most requested feature, and has been implemented in the new version, with quite a distinct sound.
Notification when the login code is wrong;
Display of Open zones when arming, with audible tone
Countdown Timer for Entry and Exit with audible tone
Display of Active Security Mode - Away, Night, Day by flashing icon
Display of Alarm on Keypad,  eg Intruder, Panic, Fire, Arm fail, Low Battery, with audible alarm tone
Trouble Conditions Page
Improved Setup Screen
Arming can be Local, or Remote ie Comfort knows if you need to EXIT when arming to Away mode, depending on whether you are local or remote. If you are LOCAL ie connected by LAN, then you need to EXIT from the Entry door in order to complete the Arm to Away Mode. If you are connected by Internet, ie REMOTE, you do not need to EXIT to arm to Away Mode.
Arming remotely (ie connected by INTERNET) will require another login for security purposes.
Up to 4 IP Cameras can be shown
Display of Connection status to the UCM/Ethernet
  • Connected
  • Disconnected
  • Data Error
The Comfort APP will automatically log out when manually disconnected or when the app goes into the background, ie log out of Comfort before disconnecting.
Multiple IP access has been ruled out due to security issues as discussed in http://www.comfortforums.com/forum66/2141.html
Please note that Comfort firmware 6.004 or above is required for the app to work fully. Firmware 6.004 is not released yet but is expected in a few days
If Comfort firmware 5.215, which is the older version is used, the only difference will be the following
  • When arming to AWAY mode when connection is by Internet ie Remote Away Arming, and there are open zones all open zones will be automatically bypassed and the system is armed without any exit delay. With Comfort firmware 6.004, for Remote away arming, if there are any open zones, they will be displayed in the keypad page, and the user must press # to force arm the system, then the system is armed without needing to exit This is a better and more secure operation compared to the older firmware
Whats New in summary;
  1. Audible tone when buttons are pressed
  2. Shows exit delay countdown timer when arming
  3. shows entry delay countdown when armed and front door is open
  4. When arming to away remotely, ie connect by Internet, do not need to open and close the front door. There is also no exitdelay when arming remotely.
  5. Arming from remote needs an addtional sign in for security
  6. shows open zones when arming, like the LCD keypad
  7. Shows current alarm on the keypad eg Intruder, Panic, Fire, Communications Failure
  8. Shows the away , Night,  or Day buttons in reverse flashing when armed to that mode
  9. shows up to 4 IP cameras for local and remote IP access
  10. New Trouble page shows AC failure, Low battery, zone trouble, communications failure,  phone trouble
  11. shows connection status  - Connecting, connected, disconnected and Data error
  12. Improved set up page
  13. Last system is retained when coming back to the app so no need to select the Comfort system again eg Home, Office
There is a new update version 1.4.1 to fix some bugs
What\'s New in Version 1.41 Various minor bugfixes mainly relating to
* address entry in setup (port now dismisses keyboard)
* better handling of addresses to allow userid / password
ALERT ! BUG IN 1.41
PLEASE DO NOT UPGRADE
APPLICATION CRASHES IN HOME CONTROL MENU
Version 1.42 has been submitted today 13 August 2011 and should be ready next week
Please upgrade to 1.42 of the app which fixes the crash on the Home Control Page
