12-09-2006, 08:28 PM
Hello,
I have wired the Cequra 2 bellbox with series tamper connection using a terminal block to the case tamper as per instructions on the website except that The 1KOhm resistors are on the comfort panel instead of the bellbox. I have enabled engineer test mode therefore bypassing tamper and for the case tamper, correctly, no alarm is triggered when removing the case. However, if I try to remove the bellbox cover, the bellbox alarm is triggered although the internal alarm is not. I tried physically bypassing the tamper by connecting a wire between the tamper block terminals on the comfort board (existing connections still intact) and I was then able to remove the bellbox cover without the bellbox going off.
Everything else works fine, if not in engineer test mode, both the internal alarm and the bellbox siren go off if I try to remove the comfort case panel or bellbox cover.
I had thought that engineer test mode would disable tamper for comfort cover AND the bellbox, but this doesn\'t seem to be the case. It\'s not a major problem to simpy physically bypass the tamper, but the manual implies that I should not have to with engineer test mode.
Am I missing something?
