06-06-2007, 08:13 PM
I installed an LW10U and initially it seemed to work ok, but then stopped and refused to respond to any commands.
Now it seems to be partially working; I can switch it off ok but I cant switch it on. The return status I get (with Wizcomfort for example) is OK in both cases.
Can noise be a problem if switch off works ok or should I suspect the switch itself. I'll have to buy a new one to test this theory.
It seems realatively easy to move a plug in X10 module around the different sockets on the house ring main but for lighting circuits there doesnt seem much you can do to test for noise problems?
Any ideas appreciated.
