Quote:Over the past few weeks, I have gradually been re-locating my Comfort Pro (outside 4.226), I have also added a couple of KP04\'s. Nearly everything appears to be working as it should, with the following exceptions:-------------------------------------------------------------
1. I cannot arm to away mode from the keypads, although it works from local or remote telephones.
2. When In away mode, a visitor at the door station no longer rings my mobile, but gets prompted to leave a message.
3. When the Zones have been set to \"announce zone\" when operated, they do not.
All help appreciated
Rob
I am answering this post from another forum
When you added the extra KP04s did you set the IDs correctly on each one so they are in sequence?
Also did you set the number of keypads in Comfigurator?
If several keypads have the same ID then each may not respond correctly
The 2nd problem appears to be due to a Response to Record a message at the door station after x seconds
If the system does not dial out in away mode check the Doorbell alarm type has dial out enabled
and the phone index for the mobile phone is checked
3rd problem - you need to look at the actual response. For example does the announcement depend on a flag being set?
regards
