Hi,
I’ve been trying to update the firmware in a UCM/USB module.
It has 7.110 in it and is working with that. I have a comfort ultra II with firmware 8.013 and I am connecting in through a different UCM/ETH03 to do the upgrade with.
I’ve tried to upgrade to the latest 8.054 and 7.225 but when I do the module communicates with Comfort but not on the USB port. The FTDI drivers are correctly installed. What I noticed was
7.225 the ucm communicates with comfort but not directly on the usb port. The com port is missing in device manager until I press and hold down the reset button on the ucm. Whilst the reset button is pressed the device appears in device manager (both com port and serial converter entries). As soon as I let go of the reset button the device disappears.
8.054 the same as above happens however the error LED is also on. I read this is to do with the ucm thinking it has a WiFi module attached but it doesn’t.
I reverted the firmware back to 7.110 and the ucm works again. Any help would be appreciated.
Jon
Jon
