Door station calls to mobile phone
How can I program Comfort system using Comfigurator so that it can do the following jobs?
1. \"When the Comfort system is armed, if a visitor press the door station (DP03), it can call to my mobile phone, so that I can talk to the visitor\"
2. \"I can use my mobile phone to call to my Comfort system and speak out thru keypad (KP04).
Thank you.
For Door Station Dialout;
Go to Alarm Types, select Doorbell. This alarm is activated when the doorbell is pressed when the system is armed to Away or Vacation Mode
Enable the dial out by checking the dialout box and select the phone (1 to 8) to dial out
For Keypad Intercom
Call to Comfort, sign in using * + (code)+ # key
The voice menu will be heard
Press 5 for Voice Station to intercom with the door station
If you have more than 1 keypad, the menu will say \"select station to to N\" where N is the number of  keypads
Is it possible to get comfort to dial out if there has been no response on the keypads or local phones?  Woprking on a Big House on a farm so they could be walking around out side without the alarm set.
There is an action \"Force Dialout for Door station\" which forces the door station to dial out when it is part of the Doorbell Response. It will not work at the end of a Timer delay
What you can do is to start a timer when the doorbell is first pressed say for 60 seconds
When the doorbell is pressed, if the timer is running, ie if it is within 60 seconds of it being pressed the first time, Force Door station Dialout.
Usually people will press the doorbell again if there is no answer.
You can refine the response by using another timer for say 10 seconds so that if the doorbell is pressed within 10 seconds it will not force the dial out, to cater for people pressing the doorbell several times in a short period
Could you possible put that in a demo program?
Try the attached file. This has not been tested and may need some refinement
On the 2nd press of the button within 10 to 60 seconds after the 1st press, it will force a dialout
.ccl   Force Doorbell dialout 2nd time.ccl (Size: 47.04 KB / Downloads: 20)
The revised attached file has been tested
On the first press, the doorbell announces \"Doorbell\"
Timer 2 will stop the ringer after 10 seconds and announce \"doorbell stop\"
When the doorbell is pressed again wuthin 60 seconds, the door station announces \"Doorbell call\" and dials out
.ccl   Force Doorbell dialout 2nd time rev2.ccl (Size: 47.71 KB / Downloads: 24)
So it rings the local phones/kepad for ten seconds then stops if it is pressed again withen 60 seconds it  rings out?
That right. The say words action is used to make the announcements \"doorbell\", DoorBell end\" and \"doorbell call\" and can be changed if required, or you can play Reminder messages which you can record.
The timer values of 10 seconds and 60 seconds can also be changed
I presume that the \"say words\" action = Action code 199 , in your attached example
When I try and program this Action code 199 response, it doesn\'t work. The date/Time is announced instead of the words I program.
I have a Comfort pro Gen1, with v4.22 firmware. Was this Action code 199 added in later Firmware releases?
