I have Zwave3 (2012) UCM running firmware 6.019 and when I try an upgrade via BUS (I have Eth2/UCM) it failed with a Bus Firmware upgrade not Supported error
I have tried upgrading both with 6.024 and the latest and they fail
Hi, I try to duplicate your problem on my side, but it works fine when I upgrade UCM/Z-wave via BUS(Eth02).
You may refer here for more information http://www.comfortforums.com/forum111/
The Zwave UCM is at 6.019, I will check what the Eth2 UCM firmware is tonight (if thats what you are referring to?) and put up some screen shots
One thing to note (me just being sill I guess). The firmware upgrade requires the user to press F0 on the keypad. Is this...
In security off mode, just press F followed by 0?
In security off mode, just press F and 0 together?
In security off mode, just press F and 0 together for a few seconds?
