03-08-2017, 07:28 PM
Hi, Just a few Questions regarding RS232 Comms from UCM to Homevision Pro which I am looking to get working.
1)I presume you don\'t have to be Logged in for the UCM to send out RS232 Data generated from a response?
2) If I use the SR00 Command to turn off Auto Status Reports, will that still allow RS232 Commands to be sent that are generated as part of a response?
3)Once Status Reports are switched off, does a reset re-enable or do you need to login and Send SR01 to re-enable?
:-for context
- What I am trying to do as a first stage is get Comfort to Report to Homevision via Serial when a Security Mode Changes.
Many Thanks
Joules
:-for context
Many Thanks
Joules
