Bypass an input from Home Assitant
What is the easiest way to bypass a zone (input) using comfort2mqtt addon?
I think the option is to use a response or counter to bypass a zone and to trigger that
(10-30-2025, 01:29 AM)slychiu Wrote: I think the option is to use a response or counter to bypass a zone and to trigger that
Thanks, so there is no direct way to bypass, I would need to create responses for each input I want to enable bypassing from Home Assistant.
Where can I find documentation to run a response from home assistant?
In the docs at http://www.comfortforums.com/thread-5575.html
The following MQTT topics are subscribed (Home Assistant  to Comfort)
comfort2mqtt/response<1 to 1024>/set - value is ignored. Comfort response is activated as programmed in Comfigurator
comfort2mqtt/counter<0 to 254>/set - 16-bit value
