- 0 Vote(s) - 0 Average
- 1
- 2
- 3
- 4
- 5
KP06 Firmware 6.004
Threads: 476
- Need engineer code to access Setting menu so that users cannot accidentally change the ID and cause a communications Failure
- \"Factory default\" option is incorporated into Setting menu. No longer triggered by holding * key for 6 secs.
The latest KP06 Firmware can be downloaded from
https://www.cytech.biz/kp06_firmware.htm...ory_id=101
Threads: 885
Known Bugs
- If a KP06 is installed at ID#1 and a 2nd KP06 is connected with the same ID without switching off the power, the ID of the 2nd KP06 cannot be changed using the * menu. The workaround is to reset Comfort. This applies to previous firmware
6 Guest(s)
