Threads: 6
We are experiencing difficulties after recent firmware updates. We upgraded to ULT7_033 and UCM7_023.
At present we are stuck at an error code UB0100FE.
The UCM/USB unit was bought some months ago to replace an older serial connection that could not be upgraded, and came with UCM7_008 pre-installed.
Upgrading the GSM and ULT firmwares where without error prior to this update.
We have tried many times to update the firmware without success and even use of the programming cable (including shunt on main board at pp2, and correct connection of all cables to ucm and from the main board) has been unsuccessful.
We also have powered down the system many times. It seems the UCM is now unreachable and has corrupted firmware.
Much time has been lost between this and another problem yesterday with a sim card not being recognised/usable by comfort.
Can you supply a solution?
Threads: 476
Is the problem with upgrading the ucm/USB?
In order to upgrade by ucm cable you need another ucm/USB or eth02
How did you originally attempt to upgrade the ucm?
If the firmware is corrupted and you do not have another ucm your distributor should be able to upgrade the ucm for you
You would have to send it back to him
Apologies for the problem
The later ucm firmware should not have upgrade problems
Threads: 6
06-28-2013, 04:32 PM
(This post was last modified: 06-28-2013, 04:33 PM by lennyh.)
The supplier stipulated that once the ucm is 6.008 and above it can upgrade itself as well as other boards. Where we mistaken in assuming this was correct? The errors occurred after we attempted this suggested upgrade path. The USB/UCM was supplied to us with 7.008 firmware.
Threads: 6
07-01-2013, 02:31 PM
(This post was last modified: 07-01-2013, 02:32 PM by lennyh.)
Before we knew about the post you have brought to our attention Comfigurator (the latest version)firmware upgrade was giving us no 2nd and 3rd option. The only option we had in Windows 8 64bit was upgrade by programming cable. That is how we proceeded with all firmware upgrades.
That clearly is why the UCM upgrade failed as it should have been done by the suggested method in your 2nd last post. After the failed upgrade we went to windows 7 32 bit and that\'s where we had options by direct cable and cbus.
The solution in your post was not found by us even after a good amount of searching. We are glad that the links have been updated.
At present we are not able to scan for all modules as there is an error. We are not able to investigate further as the contents of our panel are in the post to our supplier.
On investigating the progman.pdf we see the same detail as to upgrading as you have suggested. We chose to go with the forum initially because it seemed like the most probable place to look for up-to-date information.
Threads: 6
07-02-2013, 08:00 AM
(This post was last modified: 07-02-2013, 08:03 AM by lennyh.)
We use the 32 bit windows 7 OS as a backup and it unlike windows 8 had an older version of comfigurator. This version gave us the additional options on the upgrade page we where viewing, but this was only a recovery attempt after the upgrade failed on windows 8.
We are glad that posts and links have been updated, as we feel this was the major contributing factor in our failed firmware upgrade.
