Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
System restarts when opening the Garage Door
#1
I had two cases where when opening the garage door, the control panel did a soft reset. The first occurrence the alarm was in day mode (which was a concern as the panel takes a while announcing zones before re-arming).
I looked at the logs and found the following
Code:
 10/25 12:10 DSP/Voice Fail 1
 10/25 12:10 DSP/Voice Restore 97
 10/25 12:10 Reset 97
The same issue was in my older logs
Code:
 12/03 11:31 DSP/Voice Fail 32
 12/03 11:31 DSP/Voice Restore 97
 12/03 11:31 Reset 97
I am using Comfigurator 3.9.2 with Ultra II version 7.061, two slaves (version 6.068)
Reply
#2
DSP Voice Reset occurs when the voltage to the DSP falls to a low level and the voice is disabled to prevent corruption and lost voice. Comfort automatically resets itself to recover the voice, hence \"Voice Reset\"
The garage door operation may have caused the voltage on the system to drop momentarily. Perhaps due to a noise spike or could it be a problem with the backup battery?
Reply
#3
Running the garage door motor from the Comfort 12V supply?
Reply
#4
[user=436]Ingo[/user] wrote:
Quote:Running the garage door motor from the Comfort 12V supply?
No, the garage door has it\'s own 24 volt battery.
Reply
#5
slychiu wrote:
Quote:DSP Voice Reset occurs when the voltage to the DSP falls to a low level and the voice is disabled to prevent corruption and lost voice. Comfort automatically resets itself to recover the voice, hence \"Voice Reset\"
The main panel is some distance away from the Garage, and they are not even connected to the same power source phase.  I had a look at other logs I saved prior to noticing the two occurrences I stated, and there is an additional DSP Voice reset that did not occur when the garage door was open.
Reply
#6
Perhaps some instability of the AC power supply or surge getting into the system from outside
The DSP reset /restore is a protective mesaure which may prevent the loss of voice
Reply
#7
(10-27-2014, 08:15 AM)slychiu Wrote: Perhaps some instability of the AC power supply or surge getting into the system from outside
Just found this thread trawling through the forum.
I have had the same problem of occasional random resets and the log suggests the last was on a sign-in:
Code:
08/20 06:25 Sign in - User # 3
08/20 06:25 Mode Change # Security Off
08/20 06:25 DSP/Voice Fail 1
08/20 06:25 DSP/Voice Restore 1
08/20 06:25 Reset Comfort Controller
08/20 06:26 Date/Time Change Comfort Controller
Not sure why just signing in would triggers a power spike.
Could it suggest battery or board are failing ?
System otherwise seems fine.
Comfort II ultra v7.201 plus SEM v7.142, UCM010 type 64 v7.176, KP06a, KP04, DS01
Reply
Forum Jump:
Users browsing this thread:
2 Guest(s)
Powered By MyBB, © 2002-2026 Melroy van den Berg.
