02-27-2007, 06:09 AM
May I know how can I view camera through Comfort System?
View Camera through Comfort System
02-27-2007, 12:59 PM
The CWM (http://www.comfortforums.com/forum49/279.html )
or the Companion touchscreens (http://www.comfortforums.com/forum35/45.html) allow IP cameras like Axis to be viewed You cannot view cameras using Comfort alone
02-28-2007, 08:48 AM
There are possibilities to watch camera\'s using comfort, if output from camera\'s is controlled by using eg. RLY01 or RLY02 relaisboards. The output can then be switched to a monitor, or time-lapse recorder etc...
I have a busch-wachter (PIR) on every side of the house (4), connected to a FINDER relay with 230Volt Coil, and 4 separate NC or NO contacts ... 1st contact for switching lights directly from the PIR 2nd contact for switching the Time-Lapse Recorder 3rd contact for switching the camera 4rd contact for switching an input of comfort to CLOSED state. But, as said (and referred to in the manuals), this is a relais solution, by which you can view the source on a 3rd party device. Comfort is only involved for switching which camera you want to view ! Kind regards, Bart
03-03-2007, 01:29 PM
Thanks Bart. Just related to this - There is a 4 camera switching application in the Application Manual on www.cytech.biz - it was written in the pre Comfigurator days.
Nigel
07-03-2012, 08:12 AM
Visit http://www.gbsdvr.com/ for buying a good security camera.
| 2 Guest(s) |
